Message |
I'm thinking the Bore is too big, or the Piston is too small.. The piston was able to Rotate on the Wristpin, and let the head of the Piston Contact the Cylinder wall.. USUALLY that says the Skirt is not holding the Piston straight in the Bore Check all of your Bore/Pistons dimensions on the install.. On other NON Nissan installs, I've FILED the head of the piston away to keep it from hitting the bore.. I'm not saying that is the solve here.. But I have seen it where the Piston Head Diameter from the factory too large, and needed to be relieved a little.. I'm curious as to what the Piston Bore clearance is.. Thanks for the Shots.. Cj
